06-15-2017 03:14 PM
I know this should be basic but I am having trouble generating a sine wave using LabVIEW. I have watched tutorials that use the signal generator and DAQ Assistant tools to generate the signal but only graph the result in LabVIEW. I followed the tutorials as instructed but when I hook up the output from the NI-9263 to an oscilloscope I don't see any signal. It works when I use the DAQ Assistant test run but not when I use the signal generator. Below I attached photos of the setup I used.
Solved! Go to Solution.
06-15-2017 10:34 PM
Two comments:
06-16-2017 09:58 AM
Thanks! It was the while loop which is pretty frustrating. Any thanks for the help and I will fix the picture size next time.
