04-25-2017 12:47 PM
Hi guys, I'm new with Labview, I'm working on a project and now I'm in the final step, I need to show some data from my website's database in my application (.exe) made with labview, is that possible? and if there's any tutorial will be helpfull!
Thanks and sorry for my English.
04-25-2017 03:52 PM
Do you have the database toolkit? Look in the Connectivity palette for a set of Database VIs. As long as you know the connection settings to the mySQL server, it is fairly simple to query a set of rows and columns. Examples are included with the toolkit.
If you don't have this toolkit, there are other toolkits that use the same ActiveX calls. One that i have use was called LabSQL. There are probably others that I am not familiar with but try one of these and post back if you have additional questions.
04-25-2017 06:18 PM
Do you have direct access to the database or is the LabVIEW application going to have to make calls to your website in order to get the data?
04-26-2017 02:50 PM
sadly I don't have connectivity toolkits so I will try labSQL, many thanks for help!
04-26-2017 02:52 PM
I do have a direct access to the database.
PS: Sorry if I wrote two messages, but I didn't know how to reply to both messages in only one message.
04-26-2017 03:00 PM
Just write your message addressing each person.
Aputman,
I want to tell you this.
Jacobson,
I want to tell you something different.
04-26-2017 03:04 PM
Aputman,
Jacobson,
This way is more informative anyways, unless you include a quote of the person you are replying to. The two separate posts that the OP made above give no indication about to whom the reply is addressed.
04-26-2017 03:57 PM
@aputman wrote:
Aputman,
Jacobson,
ok Thanks guys again sorry for spaming.
RavensFan,
Thanks also for help.
