As this is obviously a .NET interface, you have to look if there is some "unload picture" method available.
You run 32bit application on 64bit OS, correct?
Please check for memory fragmentation and make sure that test execution and reporting is configured for optimized memory behavior.
Also make sure not to run too many steps with default reporting or switch to On-The-Fly Reporting.
Norbert
Norbert
Expert: Geometry
