08-02-2005 07:42 AM - edited 08-02-2005 07:42 AM
Message Edité par faquin le 08-02-2005 07:45 AM
08-02-2005 08:18 AM
Since you say the DLL does not finish executing, you will need some method where both programs can communicate.
Here are a couple of suggestions (haven't tried any of them):
You can try using TCP (search the example finder and this site for examples and tutorials).
You can try opening a connection to the LV VI server from the DLL to set the value of the indicator.
If the DLL is threadsafe, maybe you can have another DLL which will serve as a buffer - your DLL will call it to put the data in and LV will call it to extract the data (assuming LV can call 2 threadsafe DLL functions at the same time).
08-02-2005 09:32 AM
08-02-2005 11:02 AM
08-02-2005 11:17 AM
