10-28-2015 10:49 AM
Hi everyone,
First off please bear with me as I'm still very new to Labview but I'll be as specific as I can.
I have a flow meter which uses the Hall Effect with a square wave signal output to measure liquid flow rate. The 3 pins, signal, ground and power, have been connected to ports P2.0/PF1 0, D GND and +5V respectively. I've made a simple VI to count the number of rotations, which I'll convert to flow rate at a later date. However when the flow meter is connected to a pump and the magnet is rotating the VI isn't counting anything.
Has anyone got any advice or an example of how a square wave Hall Effect sensor is used to measure flow rate? Any information which you could be provided would be much appreciated. Thanks in advanced!
Scott
Flow Meter: BIO Tech FCH-m-PP-LC
DAQ: NI USB-6001
LabView: v14.0f1 (32 bit)
10-28-2015 03:02 PM
Hi Scott,
If you plug the signal and ground into an oscilloscope, can you see your signal?
10-30-2015 04:40 AM
I have and when I pass a flow I get a signal (I'm not sure how to interpret it but I get a signal which stops when I stop the flow) which I've attached.
10-30-2015 04:44 AM
I know it sounds odd but it only counts if I physically move the flow meter about in the air, not when the magnet is rotating due to liquid flow...
