05-06-2014 12:52 PM
All,
I am trying to set up a NI 9237 cDAQ module to read 4 signals from load cells, as follows;
Load Cell Capacity: 1000lb
Load Cell Sensitivity: 3mV/V
Excitation Voltage: 3.3V (Internal)
Bridge Configuration: Full Bridge
I have AI+ connected to Pin 2, AI- to Pin 3, EX+ tp Pin 6, EX- to Pin 7, RS+ tied to EX+ (Jumper Pins 4 and 6), RS- tied to EX- (Jumper Pins 5 and 7), SC not connected
Questions:
1. Have I wired this correctly?
2. Can anyone post sample code which will display load values?
Thanks in advance.
05-07-2014 01:41 PM
Hi Diarmaede,
As long as you follow this resource, you should be good to go. Also there are example codes that come with DAQmx in LabVIEW. You can go to Help>>FInd Examples in LabVIEW. In the following pop-up menu go to Hardware Input and Output>>DAQmx>> Analog Input>>Strain-Continuous Input.vi. These two resources should help you get started.
