NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
bronco9588
Accepted Solution
Setting Input Terminal Configuation for AI Voltage DAQmx Block
I am trying to get the "input terminal configuation" input into a DAQmx "AI Voltage" block to be "Differential." I have no idea how or where to search for something like this from the functions pallate. I tried the Find Examples... thing to no avail.
Active Participant
Joseph_Loo
Re: Setting Input Terminal Configuation for AI Voltage DAQmx Block
Look at the configuration in MAX
Member
bronco9588
I can set it there in DAQ pretty easily. Everytime i save the file and shut it down, it goes back to factory defaults. I would like to avoid this if possible.
Active Participant
Joseph_Loo
I don't seem to have the problem at all. Are you sure you are saving the MAX configuration file? The information you are providing is not very descriptive. In your original post, you never mention what you did other than you have a problem.
Did you create a task and save it? Did you use the task in your VI? I think you need to be a bit more explicit if you are asking for help. My guess you did not create a task and the configuration you want is set in the task portion.
Knight of NI
Dennis_Knutson
It's an input to the DAQmx Create Channel.
Active Participant
Joseph_Loo
I create a task then just start the task. If you use the channels directly, you will need to configure the channel within your VI. When you use a task a lot of the setup disappears. It all depends on your application.
Member
bronco9588
Dennis,
You are correct, and I know that. I guess my question is... how do I find the little input block that I can specifiy as differential where the DAQmx block would make sense of the thing I am telling it to do.
Knight of NI
Dennis_Knutson
That is just basic LabVIEW. Right click on the terminal and select 'Create Constant'.
Member
bronco9588
Thanks for the help. Sorry that it is such a simple problem. I really could use a class on this stuff, but not really an option for me.
Knight of NI
Dennis_Knutson
There are numerous on-line options. You can start with this.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
