Set all Index of arrays to same value in event-structure
i have a panel with four arrays and i am using an event-structure.
Now i want that changing the index of array_1 also changes the index of the other 3 arrays to same index.
But there is only a property "value change" and no property "index-change" in the properties of the array.
So i have to read the property "index" and write it to the other array.
But: It seems as if i have to do this in the timeout-section of the event-structure.
Is there any other way to do this?
Thanks for help
Message 1 of 11
(3,489 Views)
This misses if the index is typed in, but you can address that as well.
Jim
Message 2 of 11
(3,482 Views)
Accepted by OnlyOne
You can use the mouse up event on each array to detec the event (of course that will catch not only an index change, but i don't think you care too much) and then use the "index values" property on all array to set.
See attached VI (LV2012), hope this helps
Epictetus
Antoine Chalons
Message 3 of 11
(3,473 Views)
or you can use a seperate control for setting index values and register event on that control.
Message 4 of 11
(3,455 Views)
I also thought about this, but i need to use the scrollbars of my 2D-array.
This works very good with the Mouse-Up event
Message 5 of 11
(3,440 Views)
for scrollbars also you can use property node.
When index value is greater than 0 then only show scrollbars.
Message 6 of 11
(3,430 Views)
You might want to vote for this idea. 😄
Are these arrays controls or indicators? Are all of the same type?
If they are just indicators, I would eliminate them and replace them with a table (or possibly 2D array). This way they always scroll together automatically. If they are controls and of the same datatype, you could use 2D arrays.
Using 2D data structures instead will also often simplify the diagram. You can always slice out columns as needed on the code side. The UI does not  need to care about that.
Message 7 of 11
(3,419 Views)
You can also combine the 4 arrays into 1 array of clusters and it'll be synchronized automatically.
/Y
Qestit Systems
Certified-LabVIEW-Developer
Message 8 of 11
(3,413 Views)
The arrays are indicators and all are already 2D-arrays.
I voted for the idea.
Message 9 of 11
(3,394 Views)
@OnlyOne wrote:
The arrays are indicators and all are already 2D-arrays..
You can still combine them into a table or larger 2D array that contains all data.
Message 10 of 11
(3,377 Views)
