Set Value as Default Using Property Node? (run-time)
The registry would also work, I didn't suggest it because it can be a scary experience to learn how to use (still scares me).  You can also protect (read only with permissions set ) or hide init files to prevent tampering.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 11 of 16
(1,566 Views)
Ok, thanks for the help again guys.
Ryan
LV 7.1
Message 12 of 16
(1,558 Views)
Hi all,
  Is there any problem if keep part od program as vi?
Or, what does it cause?
Message 13 of 16
(1,147 Views)
You are bumping a post which is 9 year old, if you have a question please start a new thread.
To begin using the forum please check here
Message 14 of 16
(1,135 Views)
I didn't find the date
Message 15 of 16
(1,122 Views)
Hi PauloM,
THe attachmenthave a error.
Please update with corrected example.
BYUN.
PauloM 이(가) 작성함:
I know how to do that for the complete set of controls of the application (Check attachment), for only one, I never did it.
Hope this helps,
Paulo
Message 16 of 16
(878 Views)
