Serial communication without visa
Hey
I'm working on a project with a large number of serial protocols, but unfortunately I have only two visa components and one of them do not allows connecting more
I'd love to know if there is a chance to do similar to the SoftwareSerial library of the arduino and create the same solution on the RT or the fpga of my project
And whether use of such a solution could still give me control over the rate Boud Although there will be six ports are open (though not broadcasting all together)
Thanks in advance to all helpers :D
p.s :
i have one myRio which have to visa components, but one is giving me hell.
on the arduino there is a way to transmit seriali without hardware dependencis, using the sowftwareSerial library, I'm looking for a similar thing to work with on the realTime or on the fpga.
like something that let you specify the boud rat and whether to read or recive information.
(2,680 Views)
@almogb wrote:
Hey
Please get more into deteails.
I have run aplications with more than 12 RS232 & RS485 unit, most running different protocolls . ( all kind of gages for lab testing, all running in parallel )
USB to 4/8 RS232 adaptors exists ..  even NI sells serial port boards.
I would stay with VISA, it eases the port handling a lot 🙂
Greetings from Germany
Henrik
LV since v3.1
(2,656 Views)
