05-12-2006 09:16 AM
05-12-2006 11:26 AM
Tim-
Did your program use the old serial VIs? Are you now using VISA? Download a SCADA program called Specview, www.specview.com. It is free and will run for 10 minutes without a license. It will autodetect the 818. Just tell is what protocol you are using (Bisync) and the comm port to look on. This is an excellent way to test your wiring, etc. Other than that, check your wiring, since Eurotherm's 485 nomenclature is backwards from almost everyone elses.
05-15-2006 12:54 PM
Hi Tim,
Also, make sure to update and reinstall your NI-VISA drivers. I recommend the latest version. Click here to access the download page if needed. VISA needs to be reinstalled after LabVIEW 8.0 is installed so the new LabVIEW 8.0 directory has the VISA functions. As Brian suggested, also check that you are using the new VISA VIs and not the old Serial VISA VIs from older versions of LabVIEW. Let me know if you have any questions!
Chris R.
05-16-2006 08:06 AM
Brian,
Thanks for the information on Specview.
To date I have downloaded Specview.32 version 814. I go into demo mode and set up for test communications for new configurations. In the list of devices is Eurotherm 2500, Euro_M8, and Euro 26/2700. May I use any of these for my 818 because I do not see Eurotherm 818 as a specific option to choose from the list of devices.
Timman
05-16-2006 09:25 AM
07-14-2010 11:59 AM
Hi Tim,
We are trying to let the computer talk to the Eurotherm 818 controller.
Can I know where do you get the drivers for the communication between 818 and the computer? or did you write the code yourself?
Thanks for your reply.
Lingbo
