01-26-2016 11:27 PM
Are all sensors compatible with LabVIEW and DAQ assisstant or are there any specifications ?
01-26-2016 11:29 PM
Sensors have nothing to do with LabVIEW or the DAQ assistant.
The question is whether you have a DAQ device that is cabable of reading your sensor.
01-27-2016 11:30 AM
As Ravensfan points out, the burden is on the daq.
From my experience, some sensors require differential inputs on the daq(ie- many single pwr supply sensors) Also, want the sensor output to be within range of daq. (some daqs limited on neg side) Lastly, you want 2 be sure that daq can read beyond the normal range of the sensor so you can detect an overrange condition.
good luck
01-27-2016 12:04 PM
Environment > Sensor > Signal > DAQ Device > LabVIEW > User
This is the general idea.
My guess is you're asking about DAQ Devices in general. LabVIEW and MAX are great at working with a wide range of devices, though NI equipment is obviously the easiest.
Cheers
--------, Unofficial Forum Rules and Guidelines ,--------
'--- >The shortest distance between two nodes is a straight wire> ---'
02-08-2016 11:52 PM
How to calibrate MQ-3 sensor using LabVIEW 14.0 ?
02-09-2016 02:19 AM - edited 02-09-2016 02:19 AM
Hi aishu,
such a question should be answered in the calibration manual of the sensor manufacturer!
If the manufacturer of this (cheap) sensor doesn't provide any calibration data/manual you could look for similar (but better) gas sensors and read their calibration manual. Then apply your new knowledge to your sensor…
Hint: to calibrate gas sensors you need gas compositions with known content…
