For the 12v solenoid it's possible that the unit will 'pull'
significantly more current on actuation than during hold. You need to
be sure that the power supply can handle this if your circuit is going
to be reliable. Normally the solenoid manufacturer will specify an
inrush current at some level. It depends a lot on the specific solenoid
application but 2 times the normal holding current is not un heard of.
If you don't look at this condition you could potentially overload the
diodes in the power supply if it is a really simple type without
current limiting. The transformer could overheat if you activate the
solenoid too frequently, if the diodes will stand the strain. The
thermal fuse in the transformer unit will then open and the transformer
/ power supply will be un-servicable. A fuse to protect the power
supply might be a thought as well, something like a delayed action
type. The specification of this will depend on the soelnoid
specification. This will protect the circuits if the power supply is
over rated (too large a current handling capacity) or if the power
supply does not have an 'output current overload protection circuit'
{the words here are important and not to be confused with 'thermally
fused' or 'thermally protected' for example}.
It's likely at the moment that you have no load on the solenoid i.e.
no controlled medium and this could affect the current as well.
Still it's not all bad.. for-warned is for-armed
and
even this condition can potentially be handled.. but a well specified
power supply is the best option and it's worth checking out.
