12-08-2006 11:05 AM
12-08-2006 11:18 AM
Can you attach a sketch or schematic of how everything is wired up? What current does the 5V relay draw on the coil or input side? Im not familiar with the DADPad- what do you mean by 'crashing'?
12-08-2006 11:51 AM
12-08-2006 01:29 PM
12-08-2006 01:57 PM
ACROSS THE COIL!
You may already have damaged the daq board.
12-08-2006 02:07 PM
12-08-2006 02:20 PM
12-08-2006 03:06 PM
12-08-2006 04:15 PM
alright, I'll try setting up the circuit with the diodes the way you suggested. thanks for the help Analog! i don't think the board is damaged, the DAQPad still sends and receives digital signals fine when it's not connected to the circuit. still, any suggestions you have are greatly appreciated. i'll let you all know if the current solution solves the problem. thanks again!
kyle
12-08-2006 04:36 PM
