NI Home
Cart Cart | Help
Hello Events Academic NI Developer Zone Support Solutions Products & Services Contact NI MyNI
You are here:
NI Home > NI Developer Zone > NI Discussion Forums
Reply
Member
avinash3010
Send signal from labview to simulink model.
Hello all
I want to send a digital signal which will be high when a start button is pressed and zero when stop button is pressed from labview to simulink model. Is there any simple way to do this other than sending packets through UDP, TCP/IP?
Thank you.
Active Participant
MarcoMauri
Re: Send signal from labview to simulink model.
Hi!
Are you running the model using the Simulation Interface Toolkit?
Member
avinash3010
Hi Marco
I don't have simulation interface toolkit. Is it required?
Active Participant
MarcoMauri
Give a look here:
http://sine.ni.com/nips/cds/view/p/lang/en/nid/209048
With SIT you can execute your model within Labview and can iteract easily with it, for istance exchanging I/O, setting parameters etc.
Marco
Member
avinash3010
Thank you for the advice. I'll definitely look into it.
By using this web site, you accept the Terms of Use for this web site. Please read these Terms of Use carefully before using any part of this site. Please go here for information on ni.com's copyright infringement policy.
My Profile | Privacy | Legal | Contact NI © 2011 National Instruments Corporation. All rights reserved.    |    E-Mail this Page E-Mail this Page
