06-17-2009 12:26 AM
tca-adam,
I would appreciate if you can attach the VI(Please remove your user credentials,but keep common settings as default.).
When I tried with the same VI(address-smtp.gmail.com,Port :465),I got the following error while opening the connection.
"TCP Read in OGIC_SMTP_InitializeServer.vi->OGIC_SMTP - Send Email.vi" with error code 56.
I used the same settings in my outlook and it works fine.
06-18-2009 12:51 AM
Here is my latest version of the VI.
I have added the ability to attach a screenshot as well as multiple attachments.
I still sometimes see a problem with the attachments not being released if I try to write to a data file that I have just emailed as an attachment.
Happy for anyone with more LV knowledge than me to do some tidying up additions etc.
Make sure you try it on a PC that has minimal security such as firewalls etc or turn them all off until you confirm this works then put your security back in place one application at a time and check for problems. Also try a plain text message first before trying attachments and screenshots.
I can't get it to run on a locked down work PC here, but it works fine on our standalone laptop via our Bigpond account. and wireless router.
06-18-2009 12:59 AM
Tca-adam,
Thanks for posting the VI .Unfortunately it dn't serve the pupose.
I am trying to use the application in Windows Mobile(with GPRS connectivity to transmit GPS location to an e-mail processing server...) and most of the nodes you used in your application is
not supported by the target. I was trying to use the SMTP OpenG libraries which Mercurio provided.
Please let me know if u had any success with that.
Thannks,
Manu
06-18-2009 07:21 AM
smercurio,
Attaching the OGIC_SMTP vi's to work with PDA version of Windows Mobile.
Limitations include -No file attach ,SSL and GPRS.
Hopefully the next version will be enhanced with GPRS atleast.
06-18-2009 09:28 AM
07-05-2009 07:57 PM
Hi, I`m trying to use the VI to send email in Labview 7.1, but when I wire the constructor node (NetworkCredential) to the input of the property node SmtpClient (Credentials) it indicates a wire conflict. Why is this happening, is there a problem in the System.dll? Should I update it? I browse it from C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727
When I run the gmail.vi to Labview 8.5 it works, but when I try to browse the same .dll it says that the .NET runtime engine has autommaticaly updated it.
How could I make this vi work in Labview 7.1?
07-06-2009 10:08 AM
04-19-2010 12:05 PM
Hello, I am trying to use ii from a CRIO but I haven't success. Could anz one please help me?
Thanks in advance.
04-20-2010 04:02 PM
Hi fboteroh,
The Gmail.vi will not work on a CRIO because .net does not support Real-Time.
04-21-2010 01:30 AM
That´s a pitty 😞
Tks!
