Send email on labview using the Gmail Server (TLS)
Good point Smercurio.  Also, make sure your gmail account you are pointing to is valid.
Edit:  I need to mention that your VI worked as submitted without any of my modifications.
Reese, (former CLAD, future CLD)
Some people call me the Space Cowboy!
Some call me the gangster of love.
Some people call me MoReese!
...I'm right here baby, right here, right here, right here at home
Message 101 of 114
(4,425 Views)
I don’t use any non English characters in password, and I don’t  copy and paste addresses. Sender and recipient accounts are hosted on gmail  and I’m sure that both are valid.  I’ve tried everything and it’s still doesn’t work.  I will try to run this Vi on another PC, with another version of Labview. Thank you for your help. If something else come to your mind, please post it here.
Message 102 of 114
(4,451 Views)
Solution of my problem with invaild characters is simply - name of your PC can't include any non english characters. I changed it and now it's working properly.
Happy new year everybody!
Message 103 of 114
(4,431 Views)
I am trying to send email using a VI. I followed the steps in the following link,
http://zone.ni.com/reference/en-XX/help/371361H-01/lvhowto/send_email_from_vi/
but it shows error #54.
I am using Windows XP SP3 and Labview 10.0
SMTP server : smtp.gmail.com
Message 104 of 114
(4,331 Views)
Please do a search. Your question has been asked and answered dozens of times. You cannot use the built-in SMTP VIs for servers like gmail, which require authentication. This very thread points to several solutions. Have you read it?
Message 105 of 114
(4,321 Views)
Hello,  I am trying to run the gmail.vi Eriquito posted but am getting an error.  I have attached the error message.  I can ping smtp.gmail.com with no problem but when I run the code, the last part of the code displays the attached error.
Thanks!
Message 106 of 114
(3,737 Views)
If anyone can suggest what I can do to correct this error that would be awesome!  Thanks again.
Message 107 of 114
(3,726 Views)
Okay, I figured out what the problem was.  My McAfee virus scan was blocking something and causing the error.  When I turned off McAfee, everything worked fine.  Hope this helps others!
Message 108 of 114
(3,713 Views)
Is there a way to use Gmail VI behind a proxy with authentication?
Message 109 of 114
(3,587 Views)
I am working on a Building Management System project and I need to transmit alarm situations via e-mail.
I tried the example "Send Email Using SMTP Client.vi" with the parameters in the attached file (default values). The account is correct and verifiable (I left visible password). All VI's default values controls are those who have tried. VI working without generating the errors, but do not get at the yahoo address nothing.
Can anyone send me an email using this VI from Gmail?
I tried Yahoo also:
smtp.mail.yahoo.com:587 with TLS=true
Error 363514: "LabVIEW:  An error occurred while receiving data from the network."
and GMX:
mail.gmx.com:587 with TLS=true
Error 363504: "LabVIEW:  Invalid username or password combination".
The e-mail accounts work well.
All tests are done with LV2014.
Thank you.
Message 110 of 114
(2,181 Views)
