08-27-2014 01:23 PM
Ok that will be great!
08-27-2014 01:28 PM
Okay here is the entire project saved for LabVIEW 8.2.1
08-28-2014 03:20 AM
08-28-2014 07:58 AM
Good morning, yes I have it working with TT but I am wanting more visual I am not wanting the temeperature of chamber because software for chamber already gives me that using profile, I have a device that is in chamber testing over a period of 1hr and 30 min at different temperatures, driving it to 0c then to 65c for sheltered and -40c to +65c while doing that TT is sending a STAT command evry 2 minutes and sending back 4 data results. The problem I am having is part of testing the syastem shutts off for a period of 15 minutes so we are having to start TT manually that is why I wanted to automate using LV.
Thanks for your support!
08-28-2014 08:28 AM
Exactly, the point is that you can use LV to communicate with the device using telnet the same as you are doing with TT. Since you already are familiar with using telnet (through TT) you can leverage that knowledge with LV by using the telnet client VIs.
Mike...
08-28-2014 09:05 AM
This might be silly but where is the telnet VI located?
08-28-2014 10:37 AM
If you are runing LabView 8.2.1 then you do not have the Telnet Vi's.
That was part of the Internet Toolkit add-on.
http://digital.ni.com/public.nsf/allkb/190F584418A60C0B8625745D00803410
It was not a free add-on back then but since the Internet Toolkit had been rolled into the Lab VIew package since 2011(?) the old one might be free now, but I don't know for sure.
08-28-2014 01:12 PM
Yes it is free, but you will have to download the ITK for LV2012. For LV2013 and later the telnet VIs were removed from the toolkit.
In any case, http://www.ni.com/download/labview-internet-toolkit-2012/3122/en/ is a good link for downloading the 2012 toolkit. I downloaded them and then opened the telnet example in LV2013. I had to manually search for some VIs, but everything seems to be there.
Mike...
02-28-2022 04:49 PM
Hi, RTSLVU.
I also need to communicate with a scale via Ethernet and ASCII strings. I will download and study your Thermotron VI. I just wanted to ask you a question: I don't have the physical scale with me. Do you know how I can simulate it, either using a separate computer running some communication program (Putty? Hyperterminal (which is no longer available for Windows 10)?) or within the same computer running labVIEW?
Thank you
