08-26-2014 03:35 PM
Hello everyone, I am trying to send a STAT command and receive back data using a ethernet connection. Can anyone strat me out with this..
08-26-2014 03:54 PM
Send a STAT command to what?
08-26-2014 03:55 PM - edited 08-26-2014 04:02 PM
To what instrument?
The easy way would be to use VISA
08-26-2014 04:00 PM
08-26-2014 04:16 PM
To an ACU which is a control system, I have been using Tera Term followed by a MACRO that I wrote to connect thru ethernet, send stat command and receive data back, Elevation, Azmith, Polar and signal strength.
08-26-2014 04:24 PM - edited 08-26-2014 04:25 PM
Here is a screen shot of a sub-vi I use to get information from and to control a Thermotron 8800 thermal chamber through Ethernet.
Of course you will have to parse the text returned instead of convert string to numbers like I do here.
08-26-2014 04:25 PM
Great! i will try this..Thanks!
08-26-2014 04:29 PM
08-27-2014 12:42 PM
Built Thermotron 8800 VI WITH VERSION 8.2.1 and keep getting (Selecting Values have wrong type) can someone help. Here is the VI
08-27-2014 01:21 PM
Well this was meant as an example ot how to comunicate with an instrument over Ethernet using the TCP protocal VI's.
If you actually need to comunicate with a Thermotron SE-8800 thermal chamber controller via Ethernet I will post the full VI set.
In general make your selector an Enumerated type and your case needs to match your selector values with a case for every value.
