04-24-2017 10:59 AM
Hi all,
I am using a big number of channels, each one reports to a specific voltage acquired for individual sensors. I need to set up a program where I can select a specific sensor (i.e. voltage) and that voltage needs to be represented on the screen in a graph. Ideally, every time someone pushes the LED light for that sensor, a graph of the specific sensor is displayed. This will avoid having too many graphs on the screen at the same time.
Can someone advise please? I've been using case structures but I haven't been able to make it work yet.
04-24-2017 11:41 AM
If you have the plot legend visible on the graph, you can right-click on the legend and select Visible Items->Plot Visibility Checkbox. Then the user can select whatever plots they want. You just have to wire everything into that graph.
