02-05-2016 10:40 AM
StathPol ha scritto:so for example, if a sensor (3) breaks, can't i just deactivate the boolean and work? Do I need to re-modify the vi again?
Yes, VI doesn't require to be modified for this.
02-08-2016 01:56 AM
In your current setup, you cannot "remove" one signal except the last one without "moving the other signals to different graphs".
Have you found the option to disable plots in the graph as i recommended?
Norbert
02-09-2016 04:16 AM
Do you mean the option in the visible items (Plot Legend) or to incorporate a property node?
In the plot Legend, I should see a tick box.
02-09-2016 04:25 AM
You can modify that setting using property nodes. But you can also show the checkbox and let the user decide (remove the other boolean buttons in that case).
It is your decision.
However, the DAQmx task always reads out all channels, just display removes "invalid" plots....
Norbert
02-09-2016 04:37 AM
Thanks both of you guys.
