07-09-2017 03:58 AM
in my SubVI you can enter your name with a string-input.
Now i want to use this string (name) in another VI, so the name have to be a output of the SubVI.
But i can´t select the string-input as a output?
Is this right? How can i solve this problem?
07-09-2017 04:15 AM
07-09-2017 05:08 AM
I can connect the string-input to a string-output, which could be used as output.
Is it possible, that you can´t see the string-output in the front panel?
07-09-2017 10:43 AM
I have no idea what you are trying to describe. Please attach your VI's.
From your question, it sounds like you could benefit from taking LabVIEW tutorials.
LabVIEW Introduction Course - Three Hours
LabVIEW Introduction Course - Six Hours
07-09-2017 11:40 AM
Are you trying to figure out how to assign connectors to the connector pane?
I think you would get a solution instantly if you would attach a simplified version of your VI and explain the problem in more detail.
07-09-2017 01:11 PM
