01-21-2015 08:54 AM
Search does not find objects in lvlib. 13.0.1 and 13.0.1f2, Windows 7.
First try:
Open the search dialog
Select 'Objects' radio button
Select my project as 'Application Instance:"
Click 'Select Object' button and browse to functions/file io/config file VIs/Open Config Data.vi
Search Scope is 'All VIs...'
Uncheck 'Ignore VIs in vi.lib'
Click 'Find'
Results list is empty.
At least one vi with the search target was already open.
Second try:
Open a VI with the above referenced VI
right click 'Open Config Data.vi'
select 'Find all Instances'
Results list shows all instances across several files
Observation:
Using my first search method, the name of the vi is 'Open Config Data.vi'
Using the second search method, the name of the vi is 'NI_LVConfig.lvlib:Open Config data.vi' - note full path
Am I doing something wrong with my first search method?
01-22-2015 05:44 PM
Hello Les__Bartel
Your question: Am I doing something wrong with my first search method?
You could try:
-Open the search dialog
-Select 'Objects' radio button
-Select my project as 'Application Instance:"
-Click 'Select Object' button and browse to objects in vi.lib>>select NI_LVConfig.lvlib:Open Config Data.vi
-Search Scope is 'All VIs...'
-Uncheck 'Ignore VIs in vi.lib'
-Click 'Find'
-Results list shows all instances across several files
Same result as your second try.
Regards
Frank R.
