03-29-2017 01:54 PM
So I have a need to create some block diagram comments with scripting. Using the New VI Object and a style of Label (modern) or Label (system) create my comment but neither look like the comment that I made just by double clicking the BD and start typing. Even after setting the BGColor through a property node I see the system has no block border, and the modern has a 3D looking with a larger bezel on the bottom and right. But none look like a normal comment with a black border around it. Is there a hidden classic style for a block diagram comment? Am I being to picky and should just use the modern cause its close enough?
Get going with G! - LabVIEW Wiki.
16 Part Blog on Automotive CAN bus. - Hooovahh - LabVIEW Overlord
Solved! Go to Solution.
03-29-2017 02:04 PM
Crap figured it out. I wrote a VI that would make all objects it could and cast it to a text object. It found Style IDs of 2321, 21960, 21961. The 2321 is the style I want and it is a "Free Label" style.
03-30-2017 07:29 AM
Why not mark your "Solution" as the "Solution"? Yes, you are giving yourself (well-deserved) credit, but (as you should well know) you are flagging this question for the next poor schmo who lacks your cleverness that this is a Solved Problem ...
BS
04-04-2017 03:16 PM
Sure thing Bob, I hope it was clear my apprehension came from the fact that I didn't want this to look like I intentionally posted a question I knew the answer to to get more community reputation.
