Scripting - Boolean Array to number - Setting Output Config
Hi all,
I am developing a script to place a Boolean array to Number node and change its
output configuration. I am able to create the node. But I am stuck on how to
set the output configuration using script property nodes. Please help!!
Thanks in advance.
(2,863 Views)
In order to access those configuration properties, you would need the Object Class to be linked to the actual Boolean Array to Number class.... but I can't find that class anywhere in there.
If you run the Nodes[] output through a For loop and read the ClassName property, you end up with "Function" each time, so it looks like you may be out of luck.
Cheers
--------,       Unofficial Forum Rules and Guidelines                                           ,--------
          '---   >The shortest distance between two nodes is a straight wire>   ---'
(2,851 Views)
Yeah I did notice that. but no other go. I definitely have to do it using scipting
(2,842 Views)
You can go to View > Class Browser to search for a class that might have these properties (like the whole Conversion palette), but I can't find anything.
Default is Adapt to Source... could this work without changing the property?
A workaround could be to create the FXP converter you want elsewhere in a template and copy it in to your target VI instead of creating a new node.
This could help you there. (Select, Copy, Paste invoke nodes)
Cheers
(2,824 Views)
I seem to remember that the output configuration is not exposed in the scripting API for any function. As James suggests, there's a general trick you can use for missing parts of the API, which is to create the relevant code manually and then copy it over.
___________________
Try to take over the world!
(2,704 Views)
