Scan RIO resources in PXI chassis
I am trying to find a way to scan all RIO resources in a PXI chassis programmatically.
In my PXI-1085 chassis, there can be FlexRIOs (7975R), but also VSTs (5644R and 5646R).
Using NI-VISA communication, I have been able to communicate with all those modules,but only if an Alias is set in NI-MAX.
I have'nt bee able to get the RIO resource name associated to the modules found using "VISA Find Resource" VI.
I also have 2 questions:
   - Is there any way to communicate with my modules without setting an Alias in NI-MAX?
   - How can I get the RIO resource name programmatically?
(I could set as VISA alias in NI-MAX the same name than RIO resource name but this is very restrictive when deploying the application to other configurations)
Thank you,
Adrien L.
(2,883 Views)
Accepted by topic author Adrien.L
I'm kinda guessing here - but is it possible using the System Configuration VIs? This is the library/toolkit that allows you get various information about a system (e.g. for cRIOs - the installed software) - there's a 'Find Hardware' VI in there - I would suspect that you can point that at your PXI and it will give you some information?
(blog)
(2,860 Views)
It works, I can access to RIO resource name without any VISA alias.
Thank you
Adrien L.
(2,851 Views)
