Scaling a 2D picture without using zoom factor
I'm not exactly sure what this is expected to do.  Can you elaborate?
aputman
Heads up! NI has moved LabVIEW to a mandatory SaaS subscription policy, along with a big price increase. Make your voice heard.
Message 11 of 14
(1,045 Views)
Thanks everyone for the help.  I do really appreciate it.  I have found that using several draw arcs to draw an image that is similar to the png image that I was using fixs the problems that I was having, and actually gives me more control.
Thanks again
Mitchell Worner
Message 12 of 14
(1,034 Views)
Is this just an animation?  Maybe a picture ring with images created outside of Labview that you can iterate thru.
aputman
Message 13 of 14
(1,025 Views)
@Hooovahh wrote:
LabVIEW's image format doesn't support alpha layers
To be more specific, the format does support it, but the VIs strip out the alpha value before displaying, presumably because the code for rendering it doesn't exist. It is possible to recreate the transparency on your own (if you have the bottom image too) by taking the pixel RGB values from the two images and averaging them according to the transparency value.
___________________
Try to take over the world!
Message 14 of 14
(1,009 Views)
