Scaling JPEGs to fit into picture control
Hallo NG,
I have a frontpanel with a fixed sized picture-control where I want to
display a JPEG-Image.
I use the ReadJPEG and DrawFlattenedPixmap to display. Now, if my JPEG is of
bigger size than my picture control, the rest of the image gets clipped.
How can I scale a JPEG image to fit it into the control. If the control and
the image have different aspect ratios, that's OK, I could scale it down
with fixed ratio, and leave parts of the control blank.
So again: How can I scale the images, is it possible with those two VIs
mentioned above or do I have to make it more low-level and complex ?
Oliver
Message 1 of 9
(9,163 Views)
Hi Oliver
I recently had a similar problem. I solved it the follwing way: the picture is displayed "draw flattened pixmap" in "new picture". and to this "new picture" I have referred a porperty node with "draw area size" where you can set the size of the displayed image.
Hope this could help you.
Yves
Message 2 of 9
(9,163 Views)
"Yves" schrieb im Newsbeitrag
news:506500000005000000E1450000-1002247793000@exchange.ni.com...
> Hi Oliver
> Yves
No, that's not the trick. AFAIK DrawAreaSize changes the size of the picture
control, but not the size of the displayed image. Anyway, parts of my image
would be clipped away.
At the moment, I'm thinking of unflatten the data into 2D-array and make
some scaling-transformation on this array. But before inventing the wheel
twice,
any solutions out there ?
Oli
Message 3 of 9
(9,163 Views)
Oliver;
I did a quick research on Developer Exchange. If you have IMAQ, it should be very easy. IMAQ already has functions to resize a picture, as alberto posted on 6/7/2001,/a> to a similar question.
Anthony de Vries posted on 8/16/2001 what can be called a "quick and dirty" approach. With his approach you may sacrifice resolution or even details of your image, though.
Other than that, everything point that you must write your code. Joseph Oravec posted on 9/8/2000 a possible method.
I am not sure, but I think somebody did this and has the vi's available, maybe for a fee.
Hope you are succesful;
Enrique
www.vartortech.com
Message 4 of 9
(9,163 Views)
Hi Oliver
I still believe my hint should work. I have attached a VI where a picture is taken using a Hauppage-TV-card and micro-modul-camera.
Yves
Message 5 of 9
(9,163 Views)
Is it an option for you to display in an intensity graph? That would scale the
picture automatically.
-Franz
Oliver Friedrich schrieb:
> Hallo NG,
> O
liver
Message 6 of 9
(9,163 Views)
Picture Controls have a property called "ZoomFactor".
Sletrab
Message 7 of 9
(8,328 Views)
I know it is old, but came up first when searching for the answer.
For those who need a working solution, here is one by "Knight of NI":
http://forums.ni.com/t5/LabVIEW/How-to-Resize-a-picture/td-p/246785
Message 8 of 9
(5,372 Views)
A solution I prefer to use involves .NET and a GDI Resize, this method supports many file formats, and bit depths, and seems pretty quick when .NET can be used.
http://forums.ni.com/t5/LabVIEW/Net-image-resize-how-to-convert-to-format-labview-can-use/m-p/219902...
I used it in my quick drop show VIs, to scale VI icons to fill the window size.
https://decibel.ni.com/content/docs/DOC-31302
Message 9 of 9
(5,357 Views)
