08-13-2014 02:18 AM
Hi!
I have a load cell that i want to measure the weight of an object in the unit gram (g). I have a Ni 9237 connected with my load cell. I'm aware that the NI 9237 displays the signal in mV/V. I want to scale this unit to gram. In my labview code I use the DAQ assistans and i know that I have to set my specific values from my load cell certificate in here. But i don't really see where all of my values from my load cell should be inserted. I will attach a picture of my certificate if that will help you understand it better.
I have tried a custom scaling with scaling parameters. The values for slope and intercept I had to calculate by measureing wieghts of 10g 20g 30g and so on , to see what values of mV/V they generated. Then i made a regression and took that slope and intercept, but that didn't work. I gett errors like, 200077" Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property", and it says that I need to select Newtons instead of mV/V.
I have searched on the forum, but I haven't found a direct guide to this. I know there is but seems that I'm not very good at searching info.
To be noted I have the student edition of Labview 2013
Best Regards Maurlind
Solved! Go to Solution.
08-13-2014 02:25 AM - edited 08-13-2014 02:29 AM
Hi maurlind,
that certificate doesn't provide the details of relation between weight and output. All you see is dependence of output signal vs. supply voltage (as a typical value of full/wheatstone resistor bridges).
For your error message: we cannot help as long as you don't attach your VI. (Saved for LV2011 would be fine for me.)
Which polynomial regression values did you use?
Ah, I see you're using that resistor bridge module. What excitation voltage do you use?
What's wrong with Newton outputs? You are measuring a force (aka load)!?
08-13-2014 02:44 AM
Hi!
I use 10V as excitation voltage. There is nothing wrong with newtons as outputs, I can always convert it later in my code. I tried to change to it but it didn't' work.
I used a linear regression withe the formula y=0,0362x-0,0187 where x is in gram and y in mV/V. the values 0,0362 and -0,0187 where inputted in the custom scaling parameters. Se the attached print screens. For max I inputted 3000 which is the maximum load for my load cell and min -3000, in grams.
My error comes from the DAQ assistans when I'm done with my settings and want to exit. It has nothing to do with my code.
08-13-2014 02:49 AM
08-13-2014 03:00 AM
Hi!
With output values do you mean the values from the signal?. It is calibrated so it should give out zero, or around it offcourse.
With out applying a custom scale I use the default setting except for the vex value.
Best regards Maurlind
08-13-2014 03:04 AM - edited 08-13-2014 03:05 AM
Hi maurlind,
Did you read the comments on V_excitation in the manual of your NI9237?
Yes: which signal value do you get at 3kg, at 2kg, at 1kg, at zero load?
08-13-2014 03:49 AM
Hi!
I have read about the NI 9237 from this link http://www.ni.com/pdf/manuals/374186e.pdf
What I understand is that the NI 9237 uses an internal voltage , 2.5, 3.3, 5 and 10V since my load cell need 5-12V according to my certificate I can use 10V from the NI 9237 and use then use the Vex value as 10V, or I'm I wrong? I don't know what exact voltage I must use or how I can adjust it since I haven't found any info of it. I don't have any physical manuals for my instruments at least I'm aware of, maybe in a box somewhere in my Lab.
Here are the output values that I have noted:
g | mV/V |
10 | 0,35 |
20 | 0,7 |
30 | 1,05 |
40 | 1,425 |
50 | 1,8 |
60 | 2,16 |
70 | 2,52 |
80 | 2,875 |
90 | 3,22 |
100 | 3,6 |
1000 | 35,28 |
2000 | 70,53 |
3000 | 105,78 |
08-13-2014 03:55 AM
Hi maurlind,
What I understand is that the NI 9237 uses an internal voltage…
That manual also mentions some power limits. Did you read the manual?
Here are the output values that I have noted…
The output signal of a bridge is of unit "mV" - not "mV/V"!
You get about 35µV/g (with current excitation voltage). All you need to do is to multiply your signal with this number (signal * 1g/35µV) to get your load. Either create a DAQmxScale to do this or use simple math on your signal…
08-13-2014 04:26 AM
Hi !
It worked with multiplying with that factor.
I also read that the power limit is at 150 mW. According to the pdf file i can use a full bridge of 350 ohm with 3.3V. Then I should set the Vex value to 3.3V ? Don't i have to set my NI 9237 to the same voltage as well, if so how do you do that, didn't read anything about that in the manual.
Best Regards Marulind
