08-01-2005 03:05 PM
08-01-2005 03:38 PM
Well if the guys that can produce a vi front panel with irregular boundaries are having a problem with this I guess the rest of us are lost!
See you at NIWeek
Putnam
10-23-2006 10:09 AM
10-24-2006 04:30 PM
Mattis,
What exactly is the problem that you are experiencing? Can you attach an example VI to demonstrate the problem? There is no LabVIEW 8.1. We currently have 8.0, 8.0.1, and 8.20. Which one do you have?
Normally you can resolve problems like that by using the property nodes for the different controls that you are using in your program.
10-25-2006 05:07 AM
10-26-2006 05:04 PM
In order to scale all objects on the front panel so that resizing the front panel window, resizes all the front panel objects as well, do the following:
10-31-2006 01:23 PM
11-01-2006 06:59 PM
Mattis,
If you use Rudi's suggestion, you will not have a choice to leave out front panel objects. Another way of resizing is by grouping several objects together. Then you can resize the whole group of objects at the same time. They preserve their relative size to one another. However, when you use Tab controls you cannot group the object inside the Tab control and the Tab control itself, because the Tab control is the container for your object.
Hope that helps,
11-09-2006 11:48 AM
11-26-2006 12:52 PM
