Saving spectra from a cluster of 3 elements
Hello All,
I am working on acquiring spectra from a camera attached to a spectrograph. My issue is with saving the consecutive measurements to a single file. I have a cluster of three elements as the output (x node, delta x, y). How do I save it in (x,y) pairs and append the rest of measurements to the same file.I've tried multiple functions and none of them give correct wiring due to data type.I've attached an image of the acquiring case. Thank you so much,
(2,679 Views)
Attaching an image of a small piece of a VI is almost useless to those trying to help you.  Attach an entire VI as a ".vi" file, i.e. attach real LabVIEW Code so we can really see what you are trying to do.  I, for one, am very puzzled about what you mean by a "camera attached to a spectrograph" -- are you taking pictures of spectra as they appear?  Where are the (x,y) pairs coming from?  Are they numbers, images, what?  A clearer explanation and LabVIEW Code would surely help us to help you.
(2,644 Views)
Accepted by topic author AnnaDM
Make a for loop, to which you connect the spectrum, that you acquired from the Andor API in order to loop through the whole spectrum. In the loop make:
Min Dispersion + I * Delta Dispersion
and take it out from the loop through and indexing tunnel, this will give you the wavelengths vector. In this way you will have two vectors, as needed.
If something is not clear I can draw this for you.
(2,633 Views)
Hi Aesha,
creating a X array from your min/delta values should be easy once you took the free beginner courses offered by NI:
(This might not be the best solution in terms of floating point precision but it shows basic LabVIEW concepts!)
Why do you mix SGL, DBL and integer values for your dispersion data?
(2,627 Views)
Thanks a ton nikodem & GerdW for the suggestions. It worked and I can get (x,y) pairs now.
Bob, to me I just thought that part is relevant and sufficient to post the question as the rest of the vi works ok. Thank you,
(2,596 Views)
