05-19-2014 09:47 AM - edited 05-19-2014 09:49 AM
Actually that's a snipett of a shipping example of writing to TDMS with DAQmx
I Jinged a "how to" drag-n-drop a snipett here
But, going back through your original post I see you are not using a DAQmx device so.... Use the Write to measurements file Express.vi
05-19-2014 10:32 AM
Ok i managed to get the program running but i only get 1 value in the Excel table which is the very last value i get from the thermocouple when i stop the program. How do i get multiple values?
05-19-2014 11:06 AM
Put the Write to measurement file vi IN the loop
05-19-2014 11:36 AM
What if i put the Write to measuremetn vi in a separate loop with a time delay ot 2 secs will it still work?
05-19-2014 11:39 AM
Most likely not post your updated code so we can see where you are getting stuck
05-19-2014 11:42 AM
I can't really test the program right now without my DAQ hardware thats why i am asking so man yquestions 😛
05-19-2014 11:50 AM
The time delay is about useless there The problem is your tunnel mode Right click the output tunnel and select "Concatinating"
(Hmmm.... sounds familliar. Must be a homework party somewhere.)
05-28-2014 02:28 AM - edited 05-28-2014 02:35 AM
I am using Lab View 8.5 and i dont have such output tunnel options. The time delay isnt useless because i want to get the measurements every 2 secs. When i put the time delays and write to measurment file vi in 1 loop its working but i also want to get the visualizing of the temperature on the indicators constantly not every 2 secs. Tha'ts why i am trying to put the write to measurment file and time delay in separate loop. Heres what it looksl ike .
