Background:
I use HP3566A which is multisignal spectrum analyzer. I used it to acquire and analyze vibration response from a machine.
I would like to make an imitation of HP3566A by using DAQCard PCI-4451. I use LabVIEW7.1+SVT 3.1 to develop a dynamic signal analyzer (DSA) vi, and use windows XP as the OS.
Problem:
Until now, there is some facility on HP3566A that I could not develop on my LabVIEW. It is the facility to save the measurement state and call it back when I need it, then automatically set/configure the software. Measurement state is some parameters that are used control some measurement, such as: Span frequency, freq. line, Eng. Unit, measurement type (power spectrum, FRF, etc), trigger type, averaging, and so on.
Right now, on my DSA.vi, to solve the above problem, I only can perform the saving data facility. So that, I can save the measurement state that is used on some vibration measurement. But still, every time I want to run my DSA.vi with that measurement state, I should manually type the measurement state to the front panel parameter. It is very inefficient and wasting time.
Question:
Could anyone help me to show the way in making a facility so that when I call the measurement state which has been saved before, the measurement state can automatically fulfill the parameter on the front panel?
Thank you for your kind attention
