09-27-2016 06:32 AM
Hello all,
I searched already some time on the internet and I didn't find any information that helped me solve my problem.
I have a spreadsheet which I save at the moment localy on my computer.
Now I would like to save it on the windows sharepoint:
C:\Users --> https://company.i/departement/Shared/Subject
Can someone tell me how to change that in an easy way? When I select it by hand it's working without any problem.
Solved! Go to Solution.
09-27-2016 07:24 AM
09-27-2016 07:33 AM - edited 09-27-2016 07:49 AM
Try getting rid of the https: and the forwards slashes.
While you would use the https: and foward slashes if you were accessing sharepoint from a browser, I found that there is also a network file path to the same directories that you could enter into Windows Explorer to get to sharepoint like they are normal network folders. Contact your IT department to find out what that path would be.
PS: "Department" is spelled wrong in your picture.
09-27-2016 07:43 AM
@RavensFan wrote:PS: "Department" is spelled wrong in your picture.
Not if he's french speaking
09-27-2016 07:47 AM
Hello all,
Thank you for your help.
Here the easiest way I found due to your helping information 🙂
1. You go on the sharepoint and open it in the windows explorer (see attachment)
2. You right click on a file which is located where you want to save documents
3. Click on properties
4. Copy "Location:"
5. Use this as the file path and it should work
Thank you guys
09-27-2016 07:50 AM
You're welcome.
