Save picture to bmp
I have created a case structure to save a picture to BMP format when I click on the save button wired to the selector terminal but a dialog box did not appear to prompt me to save . Which part did I do wrong? Did i wire the path wrongly?
(2,214 Views)
Hi Enriquez
If you need to have a dialog box promopting you to save, then you should not wire anything on the left side of Write BMP File. If your save (OK) button is pressed then it should normally show a promt box.
Can you upload your full program?
Nghtcwrlr
(2,203 Views)
You've not coded for any dialog to popped and prompt you to save...!! Also "path to BMP file" is an indicator (output) of the "Save to BMP" function.
You can try this.
This is just for your refernce and I've not included any error handling as such (say if you select cancel the dialog that pops-up).
I am not allergic to Kudos, in fact I love Kudos.
 Make your LabVIEW experience more CONVENIENT.
(2,200 Views)
Hi Nghtcwlr,
This is my full program.
Thanks!
(2,155 Views)
