04-06-2015 06:15 AM
Hello!
I am acquiring real time data at a fixed rate. So for example each 0.5 sec I acquire a new curve on the graph (in the front panel), and I need to save all of them automatically in a folder after stoping the acqiusition.
I am using the Get Image method to write PNG file, but this gives me only the last curve.
Is there a way to save images continuously at my acqusition rate (updating the file name each time) so as not to miss any of the curves?
Thanks in advance.
Ahmed.
04-07-2015 03:59 AM
Ahmed,
is it really necessary to store the images of the graph? Isn't it more suitable to save the data itself?
Besides those questions: If you export a graph (invoke node), you will export the graph "as is". Meaning: If you don't export the graph each 0.5s, you will only get the actually graph once you do it. The graph does not store a "history".
Norbert
04-07-2015 05:15 AM
Thanks Norbert for replying.
Image or data both are fine, I just dont wanna miss any frame.
That is exactly my question, I wanna store all the data during the run time not only the last frame, is it possible?
If I will export every 0.5 sec, it there a way to increment the file name where it stores the data so as not to overwrite it?
Ahmed.
04-07-2015 06:01 AM
You could use Write To SpreadSheet File to log your data continuously into separate files or appending to a single one.
Please note that from performance point of view, you should look into file streaming.
Norbert
04-08-2015 07:48 AM
Thanks very much for your help.
Ahmed
