Save data to one file instead of multiple
Hi everyone
I have made a VI where the intention was that the user would be able to chose what channel to log from but this way the data is stored in seperate log files. If I choose for example to activate logging on temperature and pressure I want it to save to one file instead of two seperate. How can I accomplish this?
Greetings
DP
Message 1 of 27
(3,349 Views)
Some hints:
  • Learn how to decouple DAQ and data logging: Producer/consumer design
  • Learn low level File functions, do not use Express VIs for this. TDMS is very nice option
Message 2 of 27
(3,312 Views)
Hey Blokk
I am looking at this example:https://decibel.ni.com/content/docs/DOC-2431
Are you thinking something like this?
Greetings
DP
Message 3 of 27
(3,308 Views)
@DP123 wrote:
Hey Blokk
Greetings
DP
Yes. Of course you need to modify it.
Message 4 of 27
(3,305 Views)
Ah great will try to work out how it exactly works. I just do not see how I will be able to have the same options when it comes to choosing which channels I want to log on and which channels I do not want to log. Could you give me a bit more clues :D?
Greetings
DP
Message 5 of 27
(3,300 Views)
You can pre specify the channels you want to log, and store their "index" in an array. In the logging loop you just use a for loop to get the required indexes. Then you can chose the channel index of a tdms file. Try to put together something, I can help tomorrow or others will also give hints...
Message 6 of 27
(3,298 Views)
I will try to make something till tomorrow and then we can take it from there:).
If somebody else got some hints / tips you are more than welcome to share your thoughts. Thanks!
Greetings
DP
Message 7 of 27
(3,288 Views)
Unless you need to save the file in a format other than TDMS, I suggest that you use the built in DAQmx functions for logging. No separate loops are needed and much easier to program.
See modified example attached.
Cheers,
mcduff
Message 8 of 27
(3,263 Views)
Cheers,
mcduff
As I understood, the OP wants different rates for the channels, so the built in tdms is not a go. Hmm, or could it work? I have to see tomorrow, whether a tdms will record with the different rates...?
Message 9 of 27
(3,257 Views)
Maybe I should have read the post more carefully, sorry, but I think it will record the incoming task as it is defined. Not sure about the number of samples per file, if they have different rates.
mcduff
Message 10 of 27
(3,253 Views)
