05-01-2014 10:20 AM
Has anyone run across an issue with the "save as" dialog in Labview? Occasionally, if I linger too long on the "save as" dialog, LV starts to search for something and hangs (see attached). There is nothing I can do but kill LV. I've tried hitting stop and it does nothing. The search dialog is modal, so I can't select anything in the "save as" dialog. The only work around I've found is to be quick about selecting what I want to do within the dialog.
I'm currently using LV 2013 sp1, but it was also an issue before the service pack.
05-01-2014 11:08 AM
Thats a known issue resolved in the latest TSVN Toolkit release. Update the toolkit.
05-01-2014 12:05 PM
I never would have thought of the TSVN toolkit as the source of the issue. I've upgraded it now. I'll see if that fixes the issue.
Thanks!
05-01-2014 12:34 PM
And I would not have either
but the loading display was awefully familliar
