07-20-2005 09:57 AM
07-20-2005 12:04 PM
07-20-2005 12:19 PM - edited 07-20-2005 12:19 PM
Message Edited by LV_Pro on 07-20-2005 01:20 PM
07-20-2005 12:39 PM
07-20-2005 01:02 PM
When you save the file, the file dialog box allows you to name the file anything you want. If you make the file name end in a recognized extension, .txt for instance, it will then show up in Windows as a text file. Since the files are "tab" delimited, you could call them ".xls" and they would then open in Excel or whatever spreadsheet program you have. You can also go into the program and on the "open file" sub-vi connect a constant to the "default name" connector to give you a starting name when you go to save.
P.M.
