06-27-2013 02:01 PM
Hello!
I am new to labview. I was given the task of changing our SR400 gated photon counter from GPIB interface to serial RS232. I am not quite sure to go about this with the code I was given.
The sr_400 count VI writes parameters to the SR400 and then reads the data from it using the GPIB. What is the easiest way to change the VI so it uses serial RS232? Should I just removed the GPIB parts in SR400 A gate and Read and replace them with the example for RS232?
I would appreciate your help.
Thank you,
Maira
06-27-2013 02:28 PM
06-27-2013 05:03 PM
Do I need to add a configure serial port function for the write and read part or will one be enough?
Do I just directly replace the GPIB functions or do I also need to alter the stacked sequence structures?
I'm sorry to bother you but I really don't know anything about labview.
-Maira
06-27-2013 05:13 PM
08-19-2019 12:53 PM
Did you ever get this working? I'm currently in the process of trying to interface the two via RS232.
