SQL Query Works in MS SQL Server 2008 but not when using Database Toolkit
Accepted by topic author MGould
MGould,
Have you tried adding an 'OUTPUT INSERTED' clause in your SP?  Without thinking about this too deeply, I'm wondering if this will get you the result set you need.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
(lapsed) Certified LabVIEW Developer
Message 11 of 19
(1,590 Views)
I've moved on to another project, but I'll circle back and try this out in the next couple weeks.  I think you may be on to something.
Message 12 of 19
(1,586 Views)
For anyone interested I've added this to the idea exchange:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Support-for-Temporary-Tables-in-the-Database-Conne...
Message 13 of 19
(1,572 Views)
I just tried this and it appears to work.  Thanks for tip!
Message 14 of 19
(1,568 Views)
You're welcome!
I'm still unsure about this issue that's been characterized as "the DCT doesn't support temp tables", even after the NI AE "confirmed" it.  The DCT uses ADOX to do all of its work - the VIs are mostly a set of wrappers around calls to ActiveX property and invoke nodes on a set of ADOX classes.  There ARE a few limitations I've run into over the years, but mostly they're related to DCT design decisions made about mapping LV datatypes to ADO datatypes, and some weirdness about handling DB nulls, etc.  And the datatype mapping issues are, I think, partly due to the variability in datatypes available across the large number of underlying database engines that MDAC supports.  Personally speaking, I've only used it against Jet and SQL Server.
But the DCT, in this case, is just calling an Execute method on a Command object, and getting return parameters (if any) and a recordset (if any) in return.  I'm tempted to believe that your original problem may have had more to do with permissions - was the logged-in user running the LabVIEW application the same userID who verified that the SP worked correctly when it was tested in SSMS?  If you're like me, you are a DB admin whose queries always work when in SSMS, but then the LabVIEW executable runs out on the factory when the PC is logged in to a production account, and... hunh.
Permission failures in SQL-S can be subtle.  Since I haven't used temptables, I don't know what permissions need to be held to instanciate them, and whether the user automatically holds SELECT permissions on the temptable just created.
Just food for thought.  But I'm glad that you were able to reformulate your SP to just use an OUTPUT clause - seems cleaner that way, to me.
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
Message 15 of 19
(1,558 Views)
This was all running off my local DB, which is a copy of what we have running out on the factory floor.   I am working on developing new database integration into older tools so we can capture manufacturing data a little better. That being said, it could be a permissions thing.  None of us have a real solid grip on database managment and we are kind of learning as we go.  I know we do have schemea setup that limit permissions between being on the factory floor and developing, but I have no idea how that would effect what I'm working on.  I'm just a labview guy who has been drafted into the SQL army 🙂
Message 16 of 19
(1,556 Views)
I can appreciate your closing comment - my background is automated test with years of programming (HP Basic, C, and about 15 years of LV at this point), but I'm purely self-taught when it comes to DBs over the past 10-12 years. If I can get away with offering you advice at this point - forgive me if you're past this, and maybe someone else reading this will find it useful - get a good book on relational database theory. I got one by Rebecca Riordan from Microsoft Press - several years ago but the theory stays the same - and it was invaluable when helping me decide how to structure the tables and keys. After you've started to populate the tables, it's a lot more heartache to go back and fix bad design.
Good luck!
Dave
David Boyd
Sr. Test Engineer
Abbott Labs
Message 17 of 19
(1,553 Views)
Thanks David, I will put a PO in for the book.  I have been looking for a good book on database design.
Message 18 of 19
(1,537 Views)
Hello everybody,
here is a solution that works for me.
Problem: ODBC Connection, Declare variables and get Result of "Select" SQL Statement
Hope it helps you
Message 19 of 19
(1,249 Views)
