06-25-2013 06:19 PM
I am looking for a relay module (such as 9485) that could be setup as a SPDT (single pull-double throw) relay; 9485 appears to be only a SPST relay. Would NI have module or other equipment (for a CDAQ system) that would operate/could be setup as a SPDT; another possiblity would be to develop a relay board but I would prefer not to do that. The only relay modules I see are 9485 and 9481 but they are both SPST.
Alex
06-25-2013 06:42 PM - edited 06-25-2013 06:42 PM
you can connect to 2 spst relays together with a common input, but you will have to use 2 controls to output one or the other signal through common...
06-26-2013 10:09 AM
Not cDAQ and not NI examples with LabVIEW:(
http://www.phidgets.com/products.php?category=9
http://www.easydaq.biz/PagesUSB/USBRelayCardProductsFRAME2.htm
-AK2DM
06-26-2013 07:08 PM
This could work; we could use a DIO from a DAQ to toggle the relay switch.
Thanks!
Alex
06-27-2013 10:52 AM
You will need a buffer or driver between the digital ouput and the relay to provide enough current to actuate the coil.
Google ULN2003, a single chip solution that has the back EMF diode built in.
-AK2DM
