09-02-2005 09:25 AM
09-02-2005 09:42 AM
09-06-2005 12:30 PM
The SMTP VIs are not a part of LabVIEW 6.x as they are for 7.x. Upgrading would get you those, or if you cannot for some reason, they are available through the internet toolkit. ni.com is the place to go if you're interested in either of those options!
Thank you and best regards!
JLS
09-06-2005 01:53 PM
09-06-2005 09:40 PM
Yes it is possible, but never mind the SMTP VIs. A better solution is any one of a number of ActiveX SMTP components like the one from OstroSoft. The problem is that the advent of server-based spam and virus filters makes it much harder to send SMTP messages that make it through to the receiving party. Check around, there are a bunch of good alternatives. I mentioned the OstroSoft product because it's cheap (or in some cases free) and is easy to work with, but there are others that are probibly just as good.
Mike...
