03-05-2017 04:15 PM
I use the Labview built-in SMTP client library to automatically send e-mails from my application. I just found out the weirdest issue: It seems to generate a separate e-mail for each addressee! I have experienced this with gmail.
To illustrate: if I enter two addressees, I get two sent e-mails in the "sent" folder. When I send it to a gmail account, I receive it two times (even though it is only addressed to me once). When there are 3 addressees, there are 3 duplicates, etc!
I have reproduced this issue with the normal VIs and with the expressVI. Also, I have found it in LV2015 as well as LV2016.
Seems like a rather large issue to me.
Strangely enough, I don't see the duplicates appear in outlook.
03-06-2017 08:55 AM
Hi aartjan,
Just to check, the users don't receive multiple copies, but they show up in your gmail sent items?
I am wondering whether this is a feature of gmail. The last paragraph of the following article suggests this:
https://www.msoutlook.info/question/prevent-duplicate-sent-items-gmail
(External link: NI are not responsible for the content of this web page.)
Looking at the headers of these emails might help confirm whether this is the case.
Leah
03-07-2017 05:14 PM
Good suggestion, but no sigar.
First, I am using the labview built-in SMTP toolkit. It should not expose such behaviour such as storing copies.
Second: It is displaying as many copies as there are addressees! If sent to 4 recipients, there will be 4 copies in the sent folder. If one recipient is a gmail user, he/she will see 4 copies in the gmail inbox!
03-10-2017 03:44 AM
Hmm, how strange. I have a few more questions and ideas:
I'm afraid the inbuilt example has password-protected subVI's, which limits troubleshooting.
Again, I would recommend looking at the headers of the multiple messages to see if they match.
https://support.google.com/mail/answer/22454?hl=en
Leah
03-10-2017 01:37 PM
Unfortunately no solution. I use the built-in smtp library (LV 2015) as shown below.
I attached it for who would like to try to reproduce.
I used the BCC field only, but behavior is the same either way
Haven't tried a non-gmail account. I am only using its SMTP functionality
No forwarding on this account. Seen on other accounts aswell
Same behavior on port 587
Anyone able to reproduce?
03-10-2017 05:14 PM
You do understand that if you address an email to four email addresses it really has to send four separate emails to four different addresses, right?
I am not a Gmail user but maybe showing all four emails in your sent mail is just the way Gmail does it.
03-11-2017 04:52 AM
Obviously. Still, it is not normal behavior.
When I use the Outlook client to send the e-mail, I just get one message in my Sent folder. The way it should be.
Am I the only one bothered by this?
03-11-2017 08:23 AM
I'm still of the opinion that the sent items problem is a quirk of Gmail.
Are you CCing to enough people that the multiple sent items are taking up too much space, or is it bothering you because of organisation? If there's no way around it, you might be able to set up a sent items rule in Gmail to sort it out.
As for receiving the emails more than once, that is more worrying to me. If I get a free moment when I'm next in the office I'll try and replicate.
Do let us know if you find a solution!
03-12-2017 05:49 PM - edited 03-12-2017 05:51 PM
I found proof this is an issue in the library.
I tried the same thing with the same library in the technology preview and ... no more duplicates!
Unfortunately that doesn't fix the issue in my application, which was reported to me by a customer
03-13-2017 05:09 AM
Ok, I had a play around with the library and these are my conclusions:
- Sent items do indeed show differently from emails sent natively from gmail
- This still occurs if I use an array of strings in the 'to:' terminal rather than using to&cc
(Saw something about 'copies' in the function reference that made me want to try this)
- However if you put gmail in 'conversation view' (was the default setting for me), doesn't really affect what you see as each email chain only shows as 1 item
- I coudln't replicate the multiple 'received items' problem: only received each email to each account once.
Most of this data is captured in the screencap below.
I wonder what setting is causing you to receive things multiple times... Happy to provide my VI but it is basically the example one. Other than that, I'm seeing what I would expect to see and don't think the sent items thing is unexpected for SMTP. Interesting that the technology preview version doesn't do it.Could you try writing your own version of the library using example VIs on this forum?
