SMTP Email with Attachment File - array error
Hi, I'm trying to send an email including a file attachment. The file I want to include is generated by the 'write to measurement file' function with a user-specified file path input. When I try to connect the file path to the SMTP Attachments VI, I get an error saying that the source is a file path but the sink is looking for a 1D array of file paths. Is there a way to convert the originial file path into an array of paths, or an alternate method to attach the file?
I've also tried using the old 'SMTP Send Email with Attachments' function by converting the file path into a string and inputting that as the attachment path, but it also didn't work.
Thanks!
(3,552 Views)
Accepted by topic author graberse
Using the build array tool from the arrays menu should do exactly what you are looking for.
(3,543 Views)
Worked perfectly, thanks!
(3,505 Views)
 Can you share your VI
i am getiing error 56.
(3,283 Views)
