I would like to control relays to turn a heat tape on and off which requires 3-30V input. Is this possible with the SCXI-1163 Digital Output? I have a SCXI-1326 module for it. Would a wire be connected to the VCC or the Ground to get the 5 V across the channel?
Thank you,
Dustin
