07-15-2014 02:58 PM
Hello guys
I am conducting a study in which I am required to run multiple codes for different harwares simultaneously, I have the vi codes for them, I am looking for suggestions on how I can integrate them in such a way that all of them run simultaneously, can I use "Sync" option provided in the pallate.
Please suggest
Thanks in advance
Best
Deependra
P.S- All the hardwares are independent and I am not using any chassis to sync them externally, I only need to integrate the vi codes
07-15-2014 03:03 PM
Do you just want to run them in parallel or do they need a fixed timing relationship with each other.
If they should all run in parallel just call them from the same block diagram at the same time. LabVIEW will take care of the rest.
07-15-2014 03:15 PM
Hello Altenbach
Thank you for your response, yes is very vital that they all run at the same time, is it possible for you to elaborate it, as I am new to this software and still learning all the terminologies.
I am conducting a musculoskeletal disorder study and I have a VI code for an EMG (wireless) and a force plate.
Thanks ina advance
Deependra
07-15-2014 03:47 PM - edited 07-15-2014 03:47 PM
SubVIs without data dependency always "run at the same time" if called in parallel. You need to be more specific.
07-15-2014 03:52 PM
I have 2 VI codes, 1 VI code belongs to an EMG machine and the other belongs to a force plate, I am trying to figure out how to run these two aforementioned codes simultaneously.
I am uploading the codes for your reference.
07-15-2014 03:59 PM
The trigno...vi" will stop after one iteration of the loop. (unless it gets trapped in a subVI that you did not attach)
The "Single....vi" wil run until the stop button is pressed (unless it is trapped inside one of the deeply stacked loops 🐵
It is still not clear what you want. You can start them both at the same time, but it does not seem to make a lot of sense.
How old is this code? The trigno seem to be from an age where index array was not resizable (LabVIEW 4.1?)
You need to be much more specific what you want.
07-15-2014 04:15 PM
These are the codes I received from the company, even I am not sure how old they' re, and there's a whole bunch which supports them, so, it might not have worked and the trigno code won't run without the EMG machine. I just uploaded them, so that you can just have a look at it, could you please just give me a little bit of direction on how can put them in a single block diagram (like you mentioned earlier) and call them. It will serve as an exercise for me as well, as I am trying to learn this software.
07-15-2014 04:16 PM
(I doubt this will solve your problems... :o.)
07-15-2014 04:25 PM
Yes you' re right, it doesn't , I have already tried that..
Do you have any other suggestion, here's what I am trying to do.
We' re trying to conduct a study on lower back disorders, this study would involve human subjects performing pre defined tasks, and using those tasks, we' ll do the DAQ, the subject would do the task like lifting weight or body movements whilst standing on the force plate and the designated portion of his body would be attached with censors for EMG collection.
We' re trying to control the EMG and the force plate using LabVIEW, now for the data acquisition, it is very important that these two codes run simultaneously, as we' re trying to do the DAQ from both the force plate and the EMG.
That's why I am trying to find a way in which I can integrate these two codes such that they both run simultaneously.
07-16-2014 07:05 AM
Are you just reading from the EMG and force plate?
I'm not hearing anything that says you need absolute synchronization. So I would just run them as two separate subVIs. You will want to get away from the example and use the actual driver VIs. If they both are just reading, them put then in the same loop. Read the EMG then read the force plate. Do whatever with the data and loop through it again. This usually works well as a Queued Message Handler.
