08-13-2015 07:43 AM
It is possible to running the executable's LabView in the embedded board?
like a raspberry pi 2, minnowBoard, BeableBone?
Solved! Go to Solution.
08-13-2015 07:54 AM
08-13-2015 08:00 AM
There is a group working on making a LabVIEW compiler for Raspberry Pi. I think it is due out later this year. I'm not finding the email talking about it right now, but I'll keep my eyes open for it.
08-13-2015 08:12 AM - edited 08-13-2015 08:14 AM
That's the one - http://www.tsxperts.com/labviewforraspberrypi/
Looks really cool, but still some time away.
Edit - it should be pointed out that they do already have the Arduino version out. I haven't had a chance to use it, but obviously the Pi is a more promising target due to its advantages.
http://www.tsxperts.com/arduino-compatible-compiler-for-labview/
08-13-2015 08:21 AM
Thanks so much for your reply.
let's wait until December to see if it's good.
08-13-2015 11:27 AM
tst escreveu:
The Intel NUC works an application Labview???
08-13-2015 12:43 PM
The NUC is an ordinary x86 PC, albeit in a small form factor. Install Windows or Linux on it and it should run LV without issue.
Getting back to the Pi, a related question I've had kicking around is whether there's any prospect of getting NI-VISA, and specifically NI-VISA Server for the Pi or similar hardware? It would make for a cheap and easy way of remotely accessing instruments; put $35 worth of Pi next to the instrument(s), plug in an Ethernet cable and (for instance) a USB to GPIB converter, and then open up a remote VISA session from the actual measurement computer running LabView. I can do that now with a cheap x86 machine, but a Pi is an order of magnitude cheaper...
08-13-2015 01:13 PM
My application is a Farm Automation.
I want to use the Intel NUC or Pi 2 for controller all sensors and motors. I need to a report every day from E-mail.
08-13-2015 02:27 PM - edited 08-13-2015 02:29 PM
MinnowBoard is intel based. It should work.
08-13-2015 02:52 PM
igagne escreveu:
I live in Brazil and it is hard to find this board. Please could test for me?
