Following up one of my earlier posts, asking how to call a VI from a base
VI, and then have the two running independently of each other, I have done
it like this:
1. Open an Application Reference
2. Open a VI Reference
3. Used a Property Node, with Open the front panel.
4. Used an Invoke Node, with Run VI, with False wired to wait till done
So, this gets the VI's front panel open, and running, independent of the
caller VI.
Now there are a couple of problems.
Is there any way I can pass a variable (int) to the subVI...
I need to pass the int to tell the VI how to set itself up.
I also have a setup that sets up a reference to a VI, opens and runs it,
then runs another sub VI, but when the bottom level sub VI finishes, the
middle VI
stops but stays open... (Do you understand?) is there anyway
around that?
Slade Squire
Programmer
Rectifier Technologies Pacific
Melbourne, Australia
SladeSquire@rtp.com.au
