08-28-2012 05:27 PM
I have read a large number of post on this, but for the life of me I cannot figure out how to do this. What I would like to do is create a pop window from my main vi that is running. This pop up will display select indicator values but in an enlarge state so they will be visible from a distance. Therefore I need the values in the pop up to update along with the main vi that is running. Attached is an attempt I made from information gathered from posts. The problem is the subvi frontpanel will not be displayed when the zoom button is pushed. There appears to be a problem with how I am passing the reference to the subvi.
First am I doing this correctly? Second, how do I connect my reference in the main vi to the subvi?
Thanks in advance
Terry
Solved! Go to Solution.
08-28-2012 05:43 PM
The front panel will not open automatically when you run a VI by reference. You need to open it explicitly, which you can do with an invoke node with the method set to Front Panel -> Open. You can place the invoke node either in your main VI directly after the Run, or inside the VI itself. Are you sure you want this VI to be reentrant? That means that every time you click the zoom button you'll get a new copy of the "zoom" VI. You may want to maintain a static reference to the VI so you can pop up the same copy when the zoom button is clicked, instead of creating a new copy.
08-28-2012 06:00 PM
Here's a picture illustrating what nathand told you:
I added the "FP.Open" method in the subVI, but as he said, you can do it there or in the main VI. I like to have it in the subVI so that the user can click on the red "X" to close the subVI panel instead of clicking "stop") and the subVI will still terminate properly, but that's a matter of personal preference.
He has a good point about the re-entrancy.
I also prefer to use queues or notifiers to pass data between VIs, instead of control references, but that is also a matter of personal preference.
08-29-2012 09:05 AM
Thanks Nathand and thanks DianeS for the diagram. You both are correct I do not need to have the subvi re-entrant. But the way that I have the Zoom event wire gives me an error 1000 which states "the VI is not in a compatible state with this operation" if I do not have the subvi as re-entrant. Below is a diagram of my zoom event, what changes do I need to make?
08-29-2012 09:10 AM - edited 08-29-2012 09:11 AM
Change the "8" (which means prepare for reentrant run) wired to the Open VI Reference to 0.
8 only works if the VI is actually reentrant.
08-29-2012 09:36 AM
Sorry Dan_U, changing the 8 to a 0 only give me another error. Playing around more I found that I do not need to have the static vi reference set as Strictly Typed. Below is a diagram of what works Thanks everybody for their input.
08-29-2012 09:39 AM
Sorry, sure, with the static VI ref you already have a reference so no need to explicitely open one.
07-17-2013 02:34 AM
Hi.. im new here and i have a question that i hope to ask in right place...
and i didnt know to how to make new topic?!
i have sample subvi and i want to open and run it for many time (at same time) without closeing the other ones...
what can i do to make it possible!!??
07-17-2013 12:54 PM
Since this is an old thread that has already been marked as solved, it would be better to post this as a new question. To do this, run a search for approximately your question. If you cannot find an answer in the search results, there's a "Post this Question" link above the search results to create a new topic with your question as the subject.
Also, try to be more clear about what you want to do. Do you want multiple copies of the same VI to be running at the same time? If so, you can open multiple instances of a reentrant VI, and launch them dynamically. It may become complicated to manage all of them. It is always helpful if you attach your code to your post, even if it's incomplete or broken.
